superegor.
June 7, 2016 at 2:11 PM #7500
Hello, I open this topic for people to easily report compatibility or issues when connecting the OSSC directly to a consumer flat screen television (i.e. not monitors, PVMs or via scalers etc). Hopefully this will increase the speed at which info is gathered on TV brands/models which are suitable, without Marqs & Bucko constantly having to monitor things to update the official compatibility google sheet .
WHAT TO REPORT:
Please include at minimum
*complete TV model info
*whether linetriple (Lx3) works
*if tested, whether 60Hz SNES/SFC/NES-RGB works, and whether it has de-jitter mod or not (see further below)
*FW version usedAdditional info is also encouraged (like tested consoles, PAL/NTSC, additional modes, settings tweaks & TV input lag), but in this post I will only summarize the above essentials. Reporting monitors, projectors and other setups is of course welcome, but again, I will not summarize those in this post (at least not at this point).
Thanks to all contributors!
VARIOUS INFO
Linedouble is expected to work on all TVs, and quite few have reported SNES/NES-RGB problems. Line triple mode has had higher compatibility than expected, and compatibility can be increased further by external means. **See note at bottomLx4 and Lx5 modes are available since Feb 2017 Firmware 0.76.
FW 0.77 fixed incompatibilities with newer Samsung 4k sets.n/r – not reported or not tested
Note regarding SNES & NES-RGB
Due to sync jitter caused by a short scanline output by these consoles every other frame in NTSC mode (60Hz), SNES (irrespective of internal hardware) & NTSC NES-RGB have a higher incompatibility rate. Note that this sync jitter does NOT occur in PAL (50Hz) mode. The jitter can be removed with the de-jitter mod developed by Marqs. This modboard can now be ordered from VGP shop, when in stock.
For example, a couple of SNES-incompatible 4k Sonys (X/XD-series) have recently been reported. And several models from all brands can have problems with intermittent image dropouts in various line modes.Tweaks for Lx3/Lx4 and PAL modes
Regarding the “tweaks” referenced to achieve Lx3/Lx4 for some models, and for PAL modes, see this Tips & Tweaks thread.TO DO: better sorting and way to distinguish models that are currently on market. I am open to suggestions on this point.
LATEST UPDATE: July 10, 2020
Note that unfortunately posts with reports from mid-August 2019 to early February 2020 were all lost when VGP migrated servers, and I had not done an update to this OP during that time. Sorry!
———————————————————————————————————————————————MODELS REPORTED
Hisense
H40MEC2150 | Lx3: Y | SNES: Y | Lx4/5: N/N | shmups user xadox
H49MEC2650 | Lx3: Y | SNES: Y | Lx4/5: N/Y | shmups user xadox Also does 256×240 optimized in Lx5.
H49M3000 (4k) | Lx3: n/r | SNES: n/r | 480p x2 works markiemarcus
LTDN40K321 (4k) | Lx3:Y | SNES: n/r | zz99
55H6B | Lx3: Y | SNES: Y | Lx4/5: Y/Y* | accaris *Lx5 needs aspect ratio adjustment (?).
HL32K26PL | Lx3: Y | SNES: Y | Lx4/5: N/N | fwaggle Only works in DVI mode, i.e. no audio.
39H5D | Lx3: Y | SNES: Y | Lx4/5: Y/Y | kubilus1
LG
47LD450-ZA | Lx3: Y | SNES: Y | Lx4/5: Y/Y | eric90000
47LN5790-UI | Lx3: Y | SNES: n/r | zxthehedgehog Also 480p x2.
42LA620V-ZA | Lx3: Y | SNES: Y | Lx4/5: Y/Y | Mentski
32LJ610V | Lx3: Y | SNES: n/r | Lx4/5: Y/Y | TomDWC
32LH2000 | Lx3: Y | SNES: n/r | Lx4/5: Y/N | ukshaunLG 4k
55EF950V (OLED) | Lx3: Y | SNES: n/r | shmupsforum user Das Muel, You tube review Also handles 480p x2.
65EG9600 (OLED, curved) | Lx3: Y | SNES: Y | Lx4/5: Y/Y | ErickRPG
55UH661V | Lx3: Y | SNES: Y | Lx4/5: Y/Y | richisawesome Several pics in thread. Note! User was unhappy with some features of the TV and returned it, see link for info.
55UH615V | Lx3: Y | SNES: n/r | Lx4/5: Y/Y | TillDawn tested with PC-Engine
65B6 (OLED) | Lx3: n/r | SNES: n/r | Lx4/5: n/r /Y | BahnYuki youtube
65C7 (OLED) | Lx3: Y | SNES: Y | Lx4/5: Y/Y | BahnYuki youtube For both B6 and C7, although not explicitly stated in the youtube review, it’s implied that they are compatible with Lx3/4 as well. Confirmation post
65C6P (OLED) | Lx3: Y | SNES: Y | Lx4/5: Y/Y | RevQuixo
55B7V (OLED) | Lx3: Y | SNES: n/r | Lx4/5: Y/Y | mdd45
49UF850V | Lx3: Y | SNES: n/r | Lx4/5: Y/Y | niceyellowyellow Tested with RGB modded NTSC N64.
55EC9300 (OLED)| Lx3: Y | SNES: N | Lx4/5: Y/Y | JPeazy304 Only LG model reported incompatible with SNES!
55EG910V (OLED) | Lx3: Y | SNES: Y | Lx4/5: Y/Y* | nissling *Lx5 did not work for NES/SNES.
C8 (OLED) | Lx3: Y * | SNES: Y | Lx4/5: Y/Y* | Das Man *Intermittent dropouts in Lx5 for SNES. Can do x4 bob-deinterlace. See also report by opossum: sync issues with both SNES and NES-RGB in x5 mode.
55B8S (OLED) | Lx3: Y | SNES: Y* | Lx4/5: Y/Y | gamesfan Tested with 60Hz modded Megadrive and Master system. *Confirmed for SNES by Steo, though as for other LG OLEDs, occasional drop-outs can occur in Lx5 mode.
65SK9000 | Lx3: Y | SNES: Y* | Lx4/5: Y/Y | TooBeaucoup * Occasional drop-outs in Lx4 & Lx5 modes (SNES only).
43UK6500AUA | Lx3: Y | SNES: Y | Lx4/5: Y/Y* | Syxx *Works with all three versions of Lx5.
65C9 (OLED)| Lx3: Y | SNES: N* | Lx4/5: Y/Y | Arovane *Works with de-jitter mod, as reported by Bucko
UF 6800| Lx3: n/r | SNES: n/r | Lx4/5: n/r | DJAI Only tested with Wii in 480i/576i/480p Lx2 of 480p works.
6300 | Lx3: Y | SNES: n/r | Lx4/5: Y/Y | Luis Fonseca Tested with 60Hz modded Sega Mega Drive
Panasonic
TC-32LX60 (720p) | Lx3: N | SNES: Y | deltronik Poor scaling
TX-32LXD70 (720p) | Lx3: N | SNES: Y | coderkind
TH-50PX80U (720p) | Lx3: Y| Lx4/5: N | SNES: Y | Bironzilla 480i passthrough works, and is recommended.
TC-L32X30 (720p) | Lx3: N | Lx4/5: N | SNES: Y | Bironzilla 480i passthrough works.
TX-L37S20BA | Lx3: N | SNES: n/r| Lx4/5: N/N | cleeg
TC-P50S60 | Lx3: Y*| SNES: Y | Lx4/5: Y*/N | deltronik *with tweak
TC-P42S1 | Lx3: N | Lx4/5: N | SNES: Y | Bironzilla 480i passthrough works.
TC-P50S2 | Lx3: N | Lx4/5: N | SNES: Y | Bironzilla 480i passthrough works.
TC-P50G15 | Lx3: Y| Lx4/5: N | SNES: Y/N* | Bironzilla 480i passthrough works. SNES works but has severely shaky image.
TC-P50G20 | Lx3: N | SNES: Y | Pajamaslayer
TC-P55VT60 | Lx3: Y*| SNES: Y | Lx4/5: Y*/N | BonzoBits *With tweak
TX-P55VT50Y | Lx3: N | SNES: N| arovane NeoGeo & NESRGB also does not work
TC-P42UT50B | Lx3: N | SNES: Y | destinydoom
TX-P50G30B | Lx3: N | SNES: Y | Jamie NeoGeo doesn’t work
EZ950 (4k oled) | Lx3: Y*| SNES: Y | Lx4/5: N/N | marqs *With tweaks listed in post.
TX-P42G10E | Lx3: Y*| SNES: n/r | Lx4/5: Y*/N | Witchhunter *Lx3 semi-works, off-center with HDMI and does not work for 50Hz. Lx3 & Lx4 works with VGA adapter, but introduces frameskipping.
TX-P50GT60Y | Lx3: Y*| SNES: Y | Lx4/5: Y*/N | Gummi *With tweaks
TX-50EX700B | Lx3: Y*| SNES: Y** | Lx4/5: N/N | Steo *With tweak described by Marqs above. Update: Steo **SNES 60Hz only works in Lx3 mode, while 50Hz only works in Lx2.
TX-65AX800E | Lx3: N| SNES: n/r | Lx4/5: N/N | mrblack1
TH-55FZ950U (OLED 4k) | Lx3: Y* | SNES: n/r | Lx4/5: N/N | bonzobits *Works with tweak described by Marqs.
TX-32LMD70A | Lx3: N | SNES: Y* | Lx4/5: N/N | jsteel*Tested with RGB-NES
Philips
32PFL7762D/12 (720p)| Lx3: N | SNES: n/r | Lx4/5: N/N | JonasP Bad scaling.
32PFL6606H | Lx3: Y | SNES: Y | Lx4/5: Y*/Y | Harrumph *With tweaks
42PFL6008K | Lx3: Y | SNES: Y | eurogamer.de review
43PFT5301 | Lx3: Y | SNES: Y | Lx4/5: Y/Y* | Harrumph *320×240 optimized does not work in x5. 480i-240p transitions are very fast (≤0.3 s, tested with 240p test suite on SNES).
43PUS6501 (4k) | Lx3: Y | SNES: Y | Lx4/5: Y/Y | Harrumph Severe issues with scaling and frame conversion, not recommended!
PUS6262 (4k, 43″ & 50″ tested) | Lx3: Y | SNES: n/r | Lx4/5: Y/Y* | GTXMike Tested with PAL Playstation 1. *1600×1200 mode used.
22PFT5303/05 | Lx3: Y | SNES: Y* | Lx4/5: Y/Y | siopoudis *Only PAL mode tested.
BDM4065uc 40″ | Lx3: Y | SNES: Y* | Lx4/5: Y/Y | Nullifer*Drops signal briefly at 1-3 hour intervals
Samsung
LE32T51BX (720p)| Lx3: N | SNES: Y | HKT3030
LE19C450E1W (720p)| Lx3: Y* | SNES: n/r| Lx4/5: N/N | cleeg *NTSC only
UE32H6200 | Lx3: Y | SNES: n/r | Lx4/5: Y/Y | Sk8er000
UE32J6300 | Lx3: Y | SNES: Y | afangus
UE32J5100AK | Lx3: Y | SNES: n/r | eric90000
UA55D6000SMXXY | Lx3: Y | SNES: n/r | BonzoBits
HL67A750 | Lx3: N | SNES: Y | ShootTheCore
HG32NC690 | Lx3: Y | SNES: Y | ShootTheCore
55H8200 | Lx3: Y | SNES: Y | Lx4/5: Y/Y | komadori PAL 2x mode only
UE32K5600 |Lx3: Y | SNES: Y* | Lx4/5: Y/Y* |GameJon *Updated: All modes work after disabling GSCARTSW sync stripper. GameJon
UE32K5600 |Lx3: Y | SNES: n/r | Lx4/5: Y/Y* |vmagix *Lx5 Sega Megadrive only, sporadic and unusable for other consoles.
UN46C6300 | Lx3: Y* | SNES: Y | Lx4/5: Y*/N | funny_mikey *works but cannot adjust aspect
UN50H5203 | Lx3: Y | SNES: Y | Lx4/5: Y/Y | NJRoadfan
LE40A567P2W | Lx3: N | SNES: n/r | Lx4/5: N/N | JonasP Has pretty severe interrupt on 240p/480i resolution switch (ca 8 sec).
UN32EH4003F | Lx3: Y | SNES: Y | Lx4/5: Y/N | Neogaf user Triforce141
UN32J5003AF | Lx3: Y | SNES: Y | Lx4/5: Y/Y | retrorgb @ shmups
UE39F5300AK | Lx3: Y | SNES: Y | Lx4/5: Y/Y | andychristian
UN55J620DAF | Lx3: Y | SNES: Y | Lx4/5: Y/Y | B-Fake
H7150 | Lx3: Y | SNES: Y | Lx4/5: Y/Y | Jagasian
UE22D5003BW | Lx3: Y * | SNES: Y | Lx4/5: Y/Y | Steo *Can achieve Lx3 and Lx4 for 50Hz sources using the PAL tweaks from the tips&tweaks thread.Samsung 4k
UE55HU7200 | Lx3: Y | SNES: Y | eurogamer.de review
UN40KU6300GXZD | Lx3: Y | SNES: Y | Lx4/5: Y/Y | destinydoom FW 0.77+ required, all modes work.
UN50KU6300FXZA | Lx3: Y | SNES: Y | Lx4/5: Y/Y* | virsago FW 0.77+ required, all modes work. *Minor screen tearing with SNES in Lx5.
UN55KS8000 | Lx3: Y | SNES: Y | Lx4/5: Y/Y* | GigaTortoise Works with FW 0.77+. *SNES drops image infrequently in Lx5, otherwise fine.
UE49MU7000 | Lx3: Y* | SNES: Y | Lx4/5: Y**/Y* | James *With tweaks. **Lx4 only works with 60Hz.
UE55KS7000 | Lx3: Y *| SNES: Y | Lx4/5: Y/Y** | eric90000 *Needs tweaks with 50Hz sources. ** Not working with 50Hz sources. kingprawncrt Also Papercut
UE50MU6120KXXU | Lx3: Y* | SNES: Y | Lx4/5: Y*/Y | Steo *Lx3 needs tweak for 50Hz source, Lx4 does not work with 50Hz.
UN49KS8000FXZA | Lx3: Y | SNES: Y | Lx4/5: Y/Y* | xwred5 FW 0.78. *SNES drops image frequently in Lx5
QN55Q8F | Lx3: Y | SNES: Y* | Lx4/5: Y/Y | Jdurg *Dejitter modded SNES.
QN49Q70RAFXZA | Lx3: Y | SNES: Y* | Lx4/5: Y/Y | raincityransom *SNES only works in 2x & 5x.
Sony
KDL42W705B | Lx3: N | SNES: Y | noko_bombette
KDL40W705CBU | Lx3: N | SNES: Y | eric90000
KDL40EX655 | Lx3: N | SNES: Y | blizzz
KDL-55W829B | Lx3: N | SNES: Y | coderkind
KDL-40BX400 | Lx3: Y | SNES: n/r| Lx4/5: N/Y | Deubeul
KDL-47W805A | Lx3: N | SNES: Y | sonofmail
KDL-70R550A | Lx3: Y | SNES: Y | samson7point1
KDL-55W950B | Lx3: N | SNES: Y | edenal
KDL-46W900A | Lx3: N | SNES: Y | mimylovesjapan
KDL-50XE654 |Lx3: Y | Lx4/5: Y | SNES: Y | Bironzilla 480i passthrough works, but is very soft. Dreamcast did not work on this TV.
KDL-32XBR6 | Lx3: N | SNES: Y | Lx4/5: N/N |gpetit
KDL-50W800C |Lx3: Y | Lx4/5: Y/Y* | SNES: n/r | Shmups user Bacardi *Lx5 works in 1200 modes only and has uneven scaling. Tested with PSX only.
KDL-26L5000 |Lx3: Y | SNES: Y | Lx4/5: N/Y* |Dark Sakul *Lx5 works for “some” consoles. NeoGeo MVS works.
KDL-55X4500 |Lx3: Y | SNES: Y | Lx4/5: Y/N |SirRockALot Also 480p x2. Possibly same as XBR8 model in the US (2008). 480i-240p transitions take a few seconds.
KDL-40W730C | Lx3: N | SNES: Y | Lx4/5: N/N |dadjumper
KDL-40HX800 | Lx3: N | SNES: Y | Lx4/5: N/N |Floydthebarber
KDL-46EX500 | Lx3: Y | SNES: Y | Lx4/5: Y/N |TheRealPhoenix
KDL-55W802A | Lx3: N | SNES: Y | Lx4/5: N/N |moondino. Only accepts Lx2 but works perfectly with SFC/NES-RGB. FW 0.82.
KLV 32EX400 | Lx3: Y | SNES: n/r | Lx4/5: Y/N |PixelQuest. Lx2 doesn’t work. Also some issues with 480i/480p, but 480i works in x4 bob, and 480p in x2 mode.Sony 4k
XBR-65X80c | Lx3: Y | SNES: Y | retrorgb.com
KD49X8005C | Lx3: Y | SNES: n/r | zz99
KD65XD8577SAEP | Lx3: Y | SNES: Y | shmupsforum user Elrinth | Lx4/5: Y/Y* | Elrinth update *Lx5 only works in 1200 modes, unevenly scaled.
KD-55XD7005 | Lx3: N | SNES: N | thestr4ng3r Overall glitchy results.
XBR-55X900E | Lx3: Y | SNES: N | Lx4/5: ?/Y* | BambooTiger PS1/PS2 worked in most modes. SNES sync problems also described by copy at shmups forum.
49XE9005 | Lx3: Y | SNES: Y* | Lx4/5: Y/Y | haloharry *SNES only works in 50Hz!
XBR49X900E | Lx3: Y | SNES: N | Lx4/5: Y/Y | weux NTSC SNES does not work.
A1E 50″ (OLED) | Lx3: Y | SNES: Y* | Lx4/5: Y/Y | superlollo *PAL SNES. Also reported by PixelQuest (did not test SNES). Has some audio issues in 480ix4 & 480p x2.
TCL
40FD2700 | Lx3: Y | SNES: Y | bkbreyme Also 480p x2
S405 | Lx3: Y | SNES: Y | Lx4/5: Y/Y | DoctorPain99 Also 480p x2 and 480i passthrough. Also reported 43S405 by BahnYuki, and 49S405 NoAffinity
55P605 | Lx3: Y | SNES: Y | Lx4/5: Y/Y | BahnYuki Also 480p x2.
55R615 | Lx3: Y | SNES: Y | Lx4/5: Y/Y | cyborc Also confirmed for 65R615 MegaDrive
55C803 | Lx3: Y | SNES: Y | Lx4/5: Y/Y | scoobayy Also 480p x2.
40FS3750 | Lx3: Y | SNES: Y* | Lx4/5: Y/N | thomaskresge No 240p passthrough. BEWARE: Image is darkened and has vertical artefacts. *SNES does not work in Lx2
LE24FHDD20 | Lx3: Y | SNES: Y | Lx4/5: N/N | thomaskresge Aspect ratio cannot be corrected in Lx2 on this TV, but Lx3 is fine.
55DC766 (European model) | Lx3: N | SNES: N | Lx4/5: N/N | opossum BEWARE: not compatible with SFC or NES-RGB, and also problems with Sega Mega Drive!
Toshiba
55L421U | Lx3: Y | SNES: Y | Mikeyy00 | Lx4/5: Y/Y | FlappyRacoon
24SL410U | Lx3: Y | SNES: n/r | Lx4/5: Y/Y* | TwillightSlick *Lx4 needs dot-by-dot mode (ie 1:1) for proper aspect, Lx5 is stuck in widescreen and only 1920×1200 mode accepted.
50L2200U | Lx3: Y | SNES: n/r | Lx4/5: N/Y* | ENunn *Lx5 only in 1920×1080 mode. Cannot do 480p x2.
40L1333DB | Lx3: Y | SNES: Y | Lx4/5: Y/Y | Steo Can do 480p x2.
Vizio
E470VLE | Lx3: Y | SNES: Y | Lx4/5: Y/N | NJRoadfan
E420VLE | Lx3: Y | SNES: n/r | Lx4/5: Y/Y | acoulte Also 480p x2.
E600i-B3 | Lx3: n/r | SNES: Y | Lx4/5: n/r /Y | evilways
Vizio 4k
P502ui-B1 | Lx3: Y | SNES: Y | BahnYuki
P702ui-B3 | Lx3: Y | SNES: Y | BahnYuki
D40u-D1 | Lx3: Y | SNES: Y | Bahn Yuki youtube review
D50u-D1 | Lx3: Y | SNES: Y | shmups forum user orange808
M70-C3 | Lx3: Y | SNES: Y | Lx4/5: Y/Y* | AetherSmyth *Only on non-gaming HDMI inputs (more processing). User finds Lx3 to give the best result, using the gaming (low lag) HDMI input.
D65u-D2 | Lx3: Y | SNES: Y | Lx4/5: Y/Y | BahnYuki (shmups) youtube
M65-C1 | Lx3: Y/N*| SNES: Y/N* | *Sound issues, infrequent image drops. olsenn
M70-D3 | Lx3: Y | SNES: Y | Lx4/5: Y/Y* | SabreAZ *Similar issues to M70-C3 reported above, but can get stable input to HDMI 5 (gaming input), by cycling through the input modes.
D43F-E1 | Lx3: n/r | SNES: n/r | Lx4/5: n/r | SiLic0ne t0aD Did not have working remote at the time, but x2 works.
E500i-A1 | Lx3: Y | SNES: n/r | Lx4/5: Y/Y | Derf
M55-C2 | Lx3: Y | SNES: Y | Lx4/5: N/N | Neph
PQ65-F1 | Lx3: Y | SNES: Y | Lx4/5: Y/Y | stackcat
E420-B1 | Lx3: Y | SNES: n/r | Lx4/5: Y/Y | Destroyer-3
Miscellaneous brands:
Bauhn ATV58UHDC | Lx3: Y | SNES: Y | Lx4/5: Y/Y | fwaggle
Dynex DX-L26-10A Not compatible in any mode! Dark Sakul
Element ELST4316S | Lx3: Y | SNES: n/r | Lx4/5: Y/Y | ENunn
Fluid 8023384(The Source) 40″| Lx3: Y | SNES: Y | Lx4/5: Y/N | Bironzilla Bad processing and overall image, Dreamcast did not work. Not recommended by user!
Hitachi 32LD30U A | Lx3: Y | SNES: n/r | Lx4/5: n/r | niceyellowyellow
JVC LT-37A80ZU (720p) | Lx3: N | SNES: Y | Lx4/5: N/N | SabrinaB
Magnavox 32MF301B/F7 (720p) | Lx3: N | SNES: n/r | Lx4/5: N/N | ENunn Problems with audio.
Mitsubishi WD2000 DLP Projector | Lx3: Y | SNES: n/r | Lx4/5: Y/N | acoulte Also 480p x2.
Pioneer Kuro PDP-5020FD | Lx3: Y | SNES: Y | Lx4/5: N/N | neogaf user Beer Monkey
Sharp Aquos 80″ (?) | Lx3: Y | SNES: Y | brandonx76 Had problems with 480i.
Westinghouse DWM42F2G1 | Lx3: Y | SNES: Y | Lx4/5: Y*/N | VoltaicArts *Aspect ratio forced to widescreen in Lx4.
Westinghouse WD40FK2550 | Lx3: Y | SNES: Y | Lx4/5: Y/Y | NoAffinity Also 480p x2.
——————————————————————————————————————————————–See also the official compatibily chart for even more, including monitors.
Provisional verdict: Samsung, LG, Vizio and TCL are safe bets overall for Lx3 (and above) compatibility. For Sonys, it seems the new 4k X/XD range work with Lx3 also, but not the older W series otherwise highly praised for gaming (do note some incompatibilities with SNES!). Panasonic generally do not seem to do Lx3.Possible ”best of” list: Premium range: LG C7/8/9/X OLED; Budget range: TCL S series
**Note that line triple and SNES compatibility can also be alleviated by using scalers like Extron DSC 301 or DVDO products (low additional lag), but A/V receivers NoAffinity and even cheap no-name scalers with HDMI input such as this one have been reported to help (though the latter is not recommended for play due to excessive lag, only suitable for output to capture). Also report of soundbar with HDMI input that can take up to Lx5 signal: haloharry
June 7, 2016 at 7:17 PM #7507Excellent idea, thank you.
June 8, 2016 at 7:11 PM #7532Sony Bravia KDL-42W705B
SNES PAL (SNSP-CPU-02)
SNES PAL RGB cable from Retrogamingcables (maybe sync on Luma but I’m not sure. It was bought some years ago and it was not specified).
It works OK with default configuration.
Image is a bit dark and it shows some noise (diagonal bars).
Image is lighter with Framemeister but it still shows noise.SNES Mini. Modded with SUperCIC and RGB
RGB cable that came with the console (I don’t know how it is wired).
It works with default configuration (50 or 60 Hz) but sync is temporarily lost in some points of the tested game (DKC). When losing sync, OSSC LED goes red for a moment, the image is lost and after a moment, LED goes green and image is back.
To avoid losing sync, I have to set Analog sync LPF to 2.5 MHz.
Image is bright and it shows some noise (less than in PAL console). In 60 Hz mode noise is a bit less noticeable.
Noise is gone with Framemeister (SCART to mini-DIN with sync cleaner is used).Linetriple mode does not work in any of the SNES models. TV shows a “non compatible mode” warning.
Noise is not related to OSSC since it is also shown if I connect the consoles to the RGB input of the TV.
June 11, 2016 at 5:53 PM #7581Console used: 3-Chip Super Famicom (APU-01) with sync-on-composite cable
Sony Bravia KDL40EX655
480p – works
720p – black screen (“Unsupported Signal. Check your device output.”)ASUS VG248QE
480p – works
720p – worksMicomsoft SC-500N1
480p – works
720p – works (picture is slightly shifted to the right with a vertical line on the left)June 13, 2016 at 12:08 PM #7601Seems I can’t edit first post…
Can now edit, moved to first post.June 21, 2016 at 4:57 PM #7665Console used: SNES Model SNS-001 via RGB Scart from ebay store retro_console_accessories
Vizio 50″ P502ui-B1 |Lx2:Y|Lx3:Y|SNES:Y
Vizio 70″ P702ui-B3 |Lx2:Y|Lx3:Y|SNES:YI’m getting a 2016 75″ P series TV next Wednesday where I’ll do testing on that. I choose the Vizio TVs due to excellent input delay and phenomenal picture. Here’s a video link of me playing Sega Saturn on the 50″ TV.
July 12, 2016 at 9:45 PM #7893The model I use for retrogames is UE32H6200 and it’s compatible with both ossc’s modes 240p x3 and 480p x2
July 15, 2016 at 2:48 PM #7929CONSOLE: Natively PAL Sega Saturn, switchlessly region and Hz modded; running games from SD card via Rhea board.
TV: Panasonic Viera, LCD TX-L37S20BA, non LED backlight, 1080 native resolution.
MODE: Line Double to 480p – works nicely. Game mode on this TV only allows 16:9 aspect ratio. There is ++ dot crawl with sharpness >0.
MODE: Line Triple to 720p – black screen.July 15, 2016 at 8:24 PM #7938That’s unfortunate, many Panasonic sets do support line triple and that fixes the aspect ratio thing. Thanks everyone for reporting your findings thus far!
July 21, 2016 at 9:26 AM #8050BenQ BL2405HT – Works with LineTripplePAL mode (Source Amiga A1200 and MegaDriveII )
https://www.amazon.co.uk/gp/product/B00EQ0P7K8
Havent tested 480LineDouble yet as I need to hook up the PS2 for that
July 21, 2016 at 5:00 PM #8052Nice, Turrican 2 if I’m not mistaken? 🙂
July 21, 2016 at 8:44 PM #8058Yup 🙂
One of my fav games of all time, never get tired of the music soundtrack either
Cant wait for the orchestral album they’re doing on kickstarter 🙂
July 22, 2016 at 1:54 PM #8069Panasonic tc-p50s60
x2 480p works almost perfectly for the consoles I’ve tested so far, all perfect but Famicom
x3 720p does not work with any source
x2 480p does not work for Dreamcast, 480p pass-through is perfect (only tested dreamcast for 480p)Consoles tested:
Twin Famicom (Odd Horizontal sync issue or something, look at my NESRGB Twin Famicom thread – not sure if something is up with console)Genesis
Dreamcast
SNES (early model with native RGB)
n64
PS1
PC Engine DUO-RJuly 23, 2016 at 5:03 AM #8095Panasonic TC-32LX60
x2 works
x3 does not work
x2 480p does not workSame consoles tested as above. SNES with native RGB works. Poor scaling to 720p, scanlines look terrible.
Not a TV, but my Emachines E211H LCD supports all modes, SNES x3 looks great!
The horizontal sync issue with my NESRGB has been present on all displays.
July 24, 2016 at 3:56 PM #8118Panasonic TX-32LXD70
x2 works
x3 doesn’t work
SNES worksSony KDL-55W829B
x2 works
x3 doesn’t work
SNES works -
